Hello, the demo of the Emani template is not activated.
The photos, the examples, the modules are visible inside the server but in the front end the template is empty without examples. I tried to uninstall and reinstall everything but I can't get it to work .... can you help me? Thank you
- torteaura
- Thursday, 27 May 2021
Does the following article help you with this query?.. https://www.joomla51.com/tutorials/frequently-asked-question/what-is-the-difference-between-the-joomla-template-and-the-demo-installer
Thanks, problem solved, I was wrong at the beginning of the installation.
Now everything is OK. Thanks for the help!
Aura
Aura
Hi I have another problem ... where can I find the file to be able to translate the indicator text in the attached photo?
Aurelia
Aurelia
Is this a module extension you have installed or is it a custom module you have created?
Does the following article help?.. https://docs.joomla.org/J3.x:Language_Overrides_in_Joomla
If a custom module then simply edit the HTML code of your module.
Good morning, I purchased the j4 version of the Emmani template but I don't see it in my personal profile, I only see the version downloaded in 2021, what am I doing wrong? thanks Aurelia
Isn't it in the template downloads in your profile? See my attached screenshot.
Kindly,
Chris
Kindly,
Chris
It appears your second purchase was also for the Joomla 3 version of the template. I have amned this to the Joomla 4 version which should be now available for you to download.
