1. Ko3n
  3. Wednesday, 15 March 2023
Hey Ciaran :D
If you have a minute, please check if "Animate on Scroll" is working on Emani.
Joomla ‎4.2.9
PHP 8.1
Kindly,
Chris
Hi Chris
Testing this feature locally, it appears to be working without any issues. Would you have a URL to an example?
Thank you Chris
Your animations should be now displayed correctly.
My apologies as I had forgotten that there is a switch in the General -> Miscellaneous tab of your template settings to enabled/disable the animations that I had completely forgotten about :/
Excellent! Now everything works perfectly :)
Thanks a lot for your help!
Chris
