1. Shell
  4. Wednesday, 04 July 2018
Morning Ciaran
On the mobile version of the site the headline menu items don't link to the relevant pages, the only open the sub menus. For example:
- Current Vacancies
- Application Form
On the desktop site the Contact Us links to a contact page but on mobile all it does is open the sub menu. Is there any way around this?
Cheers
Shell
Hi Shell
May I suggest the following article on this query... https://www.joomla51.com/tutorials/item/mobile-menu-linking-parent-items
Thanks for this, I've amended the jquery.slicknav.js file as this is the only one where I can see the AllowParentLinks info but it doesn't appear to have worked on the mobile site...
Hi Shell
Thank you Shell
As your amendments effect the Slicknav mobile menu, may I suggest enabling Slicknav in the Responsive Options tab of your template settings.
Sorry to say the option is not available to make the parent items of the Slideout menu clickable.
Got the mobile menu working better now but the menu bar is in front of the company logo in the top left across mobile platforms. Can you help? Link is still as above.
Cheers
Shell
Hi Shell
@media only screen and (max-width: 1140px) {
#container_header, #container_header-sticky-wrapper {
padding-top: 40px;
Cheers!!
Last one for now, when you scroll the screen on mobile/tablet the mobile menu doesn't scroll with it.
Hi Shell
You would like the mobile menu to be fixed to the top? Note that this will make some menu items inaccessible on smaller screens if you have a lot of menu items (items appear outside of viewport).
