1. suzannek
  4. Friday, 10 February 2017
I am using the Elvira template on a number of sites. It is a really great template!
Is it possible to make the coloured interior part of the top3 modules all the same height even if text differs a little?
At the moment if I add just one word (Joomla 51) to module 3A text then the columns do not line up (This is on a fresh install of the quickstart).
I do not want to have to have the exact same text in all top3 modules every time I use the template!
Screenshot attached.
Thanks for any assistance
Suzanne
Hi Suzanne
#wrapper_top-3 {
display: flex !important;
.top-3b .module_surround, .top-3b .module {
height: 100%;
Hi Suzanne
Thank you Suzanne
I have amended your template and changed your Custom CSS to the following which has resolved the issue...
#wrapper_top-3 {
Hi Suzanne
There was one small change with your template. At the end of your templates styles.php (../templates/j51_elvira/php/styles.php) locate the following (line 367)...
.<?php echo $item->module_position; ?> .module_surround {
And replace with...
.<?php echo $item->module_position; ?> {
Hi Ciarán, thanks for your reply.
I tried adding that line but it did not work for me.
I then tried uploading the Elvira template folder from my test site (the one that you had gone in and fixed the layout of those modules on) to the live site site. I got the result that I wanted then. :)
Hi Suzanne
#wrapper_top-3 {
flex-direction: column;
Hi Ciarán,
That worked perfectly thank-you!
Suzanne
Hi Ciarán,
Thanks for your reply.
I tried adding the CSS as you described, it made a difference but it did not work as hoped.
I have attached a screenshot, the upper image of the modules is how they are with just the word joomla51 added to the text, the lower image is what happens when I add that CSS.
Any further suggestions would be much appreciated.
Thank-you Ciarán, I can now have very different amounts of text in each module and the background colours of the top 3 modules all are equal length on the fresh demoinstaller version :)
I tried adding that CSS to a live site but it does not work there.
Did you amend the template on the test site in any other way than adding that bit of CSS?
Suzanne
Hi Ciarán,
Unfortunately the suggested fix is not responsive on smaller screens. Any suggestions?
Viewed via responsinator
Many thanks
Suzanne
