1. mrdansken
  4. Saturday, 28 January 2023
Hi. Tried everything but it won't work.
J51_Layla_DemoInstaller
Duplicate entry '926-8' for key 'xd802_user_usergroup_map.PRIMARY'
Hi.
You should bring more information with you.
I have just updated to the latest Joomla version and rebuilt the demo installer for this template which should hopefully resolve this issue. To obtain simply re-download from your template downloads.
Thank you very much :D
I have the same problem with J51_Juliet_DemoInstaller. (Duplicate entry '25-8' for key 'PRIMARY') :(
I can install some and get no problems?
I have just updated to the latest Joomla version and rebuilt the demo installer for the Juliet template which should hopefully resolve this issue. To obtain simply re-download from your template downloads.
Can't see the Juliet template in downloads?
