1. belex24
  4. Monday, 25 October 2021
I tried several times to install Linda for J4, but always got this error: Duplicate entry '700-4.0.0-2021-08-17' for key 'PRIMARY'
(I deleted the database before).
Thank you for your tip.
I am also having this issue with the Juliet template.
I was able to finally install but the users table is empty.
Hi together...
it's the same problem with template "Jasmine"...: Duplicate entry '592-8' for key 'PRIMARY'
ciaran Can you please update this demo installer? Thanks a lot!
Best regards,
Bernd
Hi Alex
I have just updated to the latest Joomla 4 version and rebuilt the demo installer for this template which should hopefully resolve this issue. To obtain simply re-download from your template downloads.
Hello, it's me again, I couldn't solve the problem, do you have an idea... sorry if I write again, I put myself under a bit of time pressure because everything has always worked so smoothly so far.
Hier noch mal die Fehermeldung: http://cms.gks-sw.de/installation/index.php
Greetings Alex
I Have a new Problem with the file you have just updated = http://cms.gks-sw.de/installation/index.php
Can you help again?
Greetings Alex
Hi Alex
I have just updated the Chelsea template to the latest Joomla version and rebuilt the demo installer which should hopefully resolve this issue. To obtain simply re-download from your template downloads.
Hi Ciaran, I have the same problem with the Chelsea template... I downloaded the template from Joomla51 yesterday.
Greetings Alex
Hi roger-peter
I have just updated the Artisan template to the latest Joomla version and rebuilt the demo installer which should hopefully resolve this issue. To obtain simply re-download from your template downloads.
I tried several times to install J51_Artisam for J4, but always got this error: Duplicate entry '700-4.0.0-2021-08-17' for key 'PRIMARY'
Works like a charm now.
Thank you Ciaran.
Hi cuervo
I have just updated to the latest Joomla version and rebuilt the demo installer for this template which should hopefully resolve this issue. To obtain simply re-download from your template downloads.
Hi, I'm trying to install the J4 Central demo and I'm getting the following error: Duplicate entry '238-8' for key 'PRIMARY'. I downloaded the template today. I'm assuming it's the same issue discussed above?
Thank you Ciaran :) You rock!
Thank you for bringing this issue to our attention. We have just updated the templates demo installer and hope to have resolved this issue.
It seems this issue gets re-introduced to the template demo installer each time it is updated to the latest version of Joomla 4. Now that we are aware of the issue we will be sure to check for it as we keep the demo installer up to date.
To obtain simply redownload your template from your Joomla51 Template Downloads.
It's so weird. Sometimes it happens and others it goes OK. I currently have this Nina and two Layla in dev stages all ok now and running on PHP 8 or 8.1. Also not sure if it makes a diff but all are on a server vs local on MAMP or such.
Good luck!
I had the same experience and have been pulling my hair out. I even reinstalled MAMP much to my chagrin. I'm relieved that other users have been having the same problem. The latest version of Joomla 4 is showing Nina needs an update which makes me curious.
I' m afraid that the demo installation of NINA v1.0.8 is suffering the same issue. After trying to install the demo, the following error shows up:
Duplicate entry '700-4.0.3-2021-09-05' for key 'PRIMARY'
When re-clicking the different setup buttons, this error shows up:
The security token did not match. The request was aborted to prevent any security breach. Please try again.
Pressing CTRL+F5 (clearing cache) seams to solve the issue temporarly. At least it brings you to the next page: the admin login. But when you try to gain access as admin with your super user credentials, the next error appears:
Going to PHPMyAdmin > *.users > the list is completely empty. It seams that the demo doesn't create any admin user, even when you are requested to give a username and password.
Maybe the error is being caused due to the Joomla update v4.1.0 and Nina v1.0.8 was created under a prior Joomla version?
Any hint?
Thanks.
Thank you so much Ciaran
My frustration level with J4 right now is 12/10
Hi Alison
Thank you for bringing this issue to our attention. We have just updated both our Layla and Emani template, resolving this issue. To obtain simply redownload your template from your Joomla51 template downloads.
  • 2
