1. Digijoom
  4. Saturday, 26 February 2022
I'm trying to install the Emani J4 demo template. But in the database step in the workflow I got this error:
Duplicate entry '3-8' for key 'PRIMARY'
I read on the forum that I have to download the last template. But I used the template which I download just before installing on Feb 26, 2022.
I'm using this one: Released: 31-Jan-2021 Updated: 06-Feb-2022 Version: 1.0.4
Can you help? Thanks.
Downloading the latest download of this template should hopefully resolve the issue? We have just rebuilt the demo installer and fully tested without any issue.
Thank you for the very quick reaction. And I can say that I can install the Emani template with J4 wit success.
Small thing I experienced. I tried to install more languages but couldn't reach the languages downloads. That is someting I also had much times with J3 the last year. So I tried to go back and further to complete the installation. Then I got the message 'Error deleting the installation folder'. But I didn't know if this was something with the browser (cache). After I go to the administrator I could log in and open the site.
Thank you.
Kees
Hi Kees
Thank you for the update. Difficult to say for sure what may cause this however It sounds like there may be some issues regarding permissions on your Joomla installation. Eg. your Joomla installation does not have the permissions to delete on your server. However considering you can access the site after would suggest that you have indeed been able to delete the installation folder (root of your Joomla site).
I have another issue to report but I think this is a Joomla4 issue.
For years i'm working with a test-domain environment to make new websites before they go live.
I did also with this Emani demo template. As i said the installation was succesfull, but when I click on home or the logo I get an error.
The example for my url is 'http://testdomain.com/newsite' .
The error is : Nginx is functioning normally .
When i use an url from the site is works OK. By example: 'http://testdomain.com/newsite/index.php/features/one-page-website'.
I never has this error working with Joomla3. The hosting is by an good hostingcompany.
Do you have any idea what the cause can be?
Thanks.
