1. amo
  4. Wednesday, 06 March 2024
I have a problem with the Natalie template. I installed it on a new website and the drop down menu is displayed wrong, all the links and sublinks are displayed at once.
Can you help me?
Thanks.
Good morning
yes, thank you, I changed this within all the modules and it's working now.
Thanks a lot!
That is rather strange. May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
Good morning, I just sent you the information via mail.
Thanks.
It seems the menu override was not been created on install. I have created the override manually and the issue is now resolved.
Good morning
Thank you very much, that is working now!
But I have another issue: Its not a sticky menu, although I clicked on it in the template settings...
Thank you for looking into the matter!
another issue: if I have a image gallery in the bottom-1 or bottom-2 area, it would not show the title of the page anymore. It's like all to much at the top....
1. Does disabling the General Settings -> Overlap Header if in showcase-1# module position option in your slideshow module settings give you the desired result?
2. Would you have a URL directly to an example of this issue?
I have made a workaround, and haven't tested yet.
What's more important is that the menu does not stick on the top of the site, although ticked "Sticky Header": Yes.
Can you help me here?
Thank you!
Disabling the General Settings -> Overlap Header if in showcase-1# module position appears to have resolved the issue (homepage).
