1. mvanbergeijk
  4. Friday, 10 January 2025
I have installed DPCalendar. When I open the menu with event items the header does not appear. How to fix this?
https://ng.devportaal.biz/index.php/agenda
Marco
And this problem also appears with the component RSForms.
Please help!:D
Have you checked that the page header is enabled in the menu item settings? If yes, may I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our referece please paste a link to this post in your email.
I send you the credentials. The new url is https://www.nooitgedachtalmkerk.nl/
Kind regards,
Marco
Please, can you help me?
Thanks.
Please, can you help me? Thanks:)
I dont appear to have received your email. Could I ask you to resend your email and also cc in ciar4n@gmail.com in case your email is been blocked to the joomla51.com domain.
Oke, I send it again.
Please, can you help me!
You appear to be hiding all page headers with the following custom CSS...
.maincontent .page-header {
display: none;
I have override'd this for DP Calendar by also adding the following...
.maincontent .dp-page-heading.page-header {
display: block;
margin-bottom: 1rem;
I added both codes in the CSS custom code of the template. But the header of DPcalendar does not appear in the same way as the other menu items. Please help.
Please help to solve this issue. I can not go live with the site before this issue is solved. Thanks
I added both codes in the CSS custom code of the template..
You should delete the first code and only add the second code
I'am sorry. I replace the code, but still no correct header at the Agenda item. Please help me. Thanks
Have you since diabled the header for your 'Agenda' menu item as it is no longer displayed?
I do not disabled the Agenda menu item. Please help!
Please help!
Please can you help me. This is for my customer an serious problem. Thanks in advance!
Please can you let me know what you need to solve this problem?
Please can you help me! Thanks
To amend, try removing the following from your custom CSS...
display: none;
  • 2
