Even with that plugin enabled, I cannot get the J51 4 versions to work in Joomla 6.2. This is what I get:
The error
"0 Class 'JFormHelper' not found" And AI tells me : this is a common critical error in Joomla, typically occurring when a site is updated to Joomla 4 or Joomla 5.
When I dive deeper in this problem, I get pages full of codes that I do not understand.
What is the solution?
Kind regards, Wouter
Thank for your remarks. The Backwards Compatibility Plugin is enabled. I use the latest version of Layla that show in My Downloads a Layla 4. There is no separate Layla 5. On the J51 it is mentioned as being compatible with Joomla 4,5,6.
These are the errors that I receive after making Layla the default template:
Class "JFormHelper" is no longer supported in J5 with the J5 Compatibility Plugin disabled. Therefore, you definitely need the J5-native version of the template. Regarding the current support situation at Joomla51 (which is far from perfect, to describe the situation politely) it will be difficult for you to get reach of that version.
Also, even the J5 version will need the J6 Compatibility plugin to be functional under J6.
Heads up on the "just turn on Backwards Compatibility Plugin" - there are two choices in there - one off and one on - BOTH must be turned on.
Just a FYI
