1. mvanbergeijk
  4. Thursday, 19 December 2024
I have installed template Novah. I have included a list of articles in a menu item. However, now the page header appears twice on the page. However, I only want it to be visible once. How can I adjust this so that it is only visible once.
Thanks,
Marco
Thanks. I try all the code mentioned in the ticket. Unfortunately the header remains visible. Is there another solution available?
try: article options | list layouts | disable Table Headings
Sorry to ask, but did you enter it in the correct style that you used?
Yes, it is disabled.
What do you mean with correct style?
In a forum, you often cannot tell what level of knowledge the person asking the question has.
It would not be the first time that someone makes a change in the wrong template style that they do not even use on their website. Then they are surprised that nothing has changed.
