Hello, after I installed the nina example template, each article appears twice in the dashboard and system. Also the user menu and the link to the website in the top bar is duplicated. What can I do here? Greetings Alex
If you navigate to your module manager and set to administrator modules, do you have duplicates of some of the modules? Does disabling any duplicates resolve the issue?
Hi Ciaran, I think I found it in the admin module section. Can I just delete the duplicates?
How can it happen that it is created twice?
Is my second template that I installed from joomla51 and is installed in the backend like this.
Yes you can simply delete or disable the duplicates. It's difficult to say how this has happened, but we will attempt to replicate the issue locally to help determine the possible cause.
