MENU
  1. patrickbmccabe
  4. Thursday, 09 February 2017
Hello Ciarán,
I uploaded Trinity to
http://www.sliabhbeagh.org/index.php
To give my client a choice, I uploaded a Second Template of yours, Boss.
This caused the Social Icons in Trinity to disappear
I re-uploaded the J51icons.zip from The Trinity template and this fixed the Icon problem
Hi Patrick
You can simply install the Maya template and navigate to your templates style (Extensions -> Templates). Click in to your new Maya template style (J51_Maya - Default) and select the Menu Assignment tab. From here you can apply your Maya template to the menu items of your choice. Both templates use the same module position naming so switching should be relatively painless. :)
Installing multiple template should not cause you any such issues. Would you have a URL to an example of the icons module within the Boss template and I will examine this issue further?
I come back to this issue from a different angle. I'm sorry if thus is a stupid question. but I have an "A+" client using the Boutique template, They are a VERY good client but VERY particular Thay want to try a new design The Maya template has been chosen. Which parts of the maya Template Downloads do I upload to ensure that the current Boutique is undisturbed BUT in a different menu The Maya Version of the same database information can be seen? :o :(
Thank you for your Patience
