1. Ale
  4. Friday, 24 April 2015
I have a problem with menu in mobile devices and the social media icons overlay in my logo.
this is the url: http://www.weaponsofconquest.com
Regards,
Hi Ale
Considering the space available your only option would be to place your icons in a single column to the right of your logo. To do so try adding the following to the Custom CSS field of your templates parameters...
#socialmedia ul {
width: 40px;
#socialmedia ul li {
float: right;
Regarding the mobile menu, there appears to be a conflict with the menu and one of the plugins used on your site. Try disabling each 3rd party plugin until you find the one conflicting. To disable 3rd party plugins navigate to your Plugin Manager (Extensions -> Plugin Manager). Sort your plugins by ID in decending order. 3rd party (non Joomla) plugins will be listed first and will have an ID number significantly higher than your Joomla plugin which will usually be in the 400 to 500 ID range.
Hi Ciaran..
I don´t find the plugin 3rd party. (I seek in the plugin manager)
I pasted the CSS code but don´t works and the social icons appears in vertical style.
Regards,
Hi Ciaran.. Ok I send to you the acces to my admin panel.
Thank´s
Thank you Ale
The issue appears to have been jQuery enabled on your slideshow module. As Joomla 3.x now loads jQuery by default, you can disable it in any of your module extensions. Your mobile menu should be now displaying correctly.
Thank Ciaran it work.
Regards,
