1. afarkas
  3. Tuesday, 19 November 2024
Does Ensley template or any of its modules/components uses "301 redirect"? If so, is there any way to turn it off?
Im using a gallery system on my site which does not works properly due to a conflict with some "301 redirect".
This is what the gallery support wrote to me regarding my problem:
"301 redirect from the server side,
The reason is in a third-party extension or you made changes to htaccess"
The only third-party extension i have installed on my site is J51 Ensley template...
Thanks for any info
The template should have no effect on your htaccess and does not set any 301 redirects. Would you have a URL to an example of the issue?
