1. mikehally
  3. Tuesday, 06 May 2014
Dropdown menus working fine when viewed on full-size screen. However when layout is narrowed for smartphone for example - i.e., when the drop down menus are replaced by the smartphone menu, only the menu parent items are displayed. Is it possible to set it up so that the child items appear also, just as they do in the drop downs?
http://www.radioindies.org/new2
Hi Mike
Thank you Mike
This appears to be a issue with the Joomla 2.5 version of the template which we are looking in to. Updating to Joomla 3.x will resolve the issue. Alternatively if you intend to continue using Joomla 2.5, we can replace your dropdown menu with a CSS3 equivalent which will also fix the problem.
just spent a fair amount of time migrating from 1.5 to 2.5 so think I'll stick with it for now ... so would appreciate your CSS3 fix for the drop down menu!
Hi Mike
We have updated the dropdown menu of the Joomla 2.5 version of our Cashmere template to CSS3 and installed it to your Joomla installation. Your mobile menu is now working correctly.
Ensure to do a full refresh on your browser to load the new CSS :)
:woohoo: you continue to amaze me! Fabulous, thanks
