1. green12
  3. Saturday, 10 February 2024
Deprecated: htmlspecialchars(): Passing null to parameter #1 ($string) of type string is deprecated in /var/www/vhosts/http://pompeionline.net/httpdocs/mm4/modules/mod_j51icons/mod_j51icons.php on line 34
Deprecated: htmlspecialchars(): Passing null to parameter #1 ($string) of type string is deprecated in /var/www/vhosts/http://pompeionline.net/httpdocs/mm4/modules/mod_j51icons/mod_j51icons.php on line 42
Hi, I solved this error on another site in J4 but now I don't remember how I did it.
Template Sophia, the error appears on the J51 icons module after doing a migration from J3 to J4
The error appears if I set the error ratio to maximum. If I don't make any changes and configure the error report to none, what problems could I have on the site? It seems to me to be working correctly. Thank you
PHP 8.1.27
I sent the email with the data, thanks
Installing the latest update of the Icons module appears to have resolved the issue (Download: https://drive.google.com/file/d/11X7ZX19INxlOt4bnPBtA0EKgPNbEH2UW/view?usp=drive_link)
Thank you very much, I couldn't find the latest version. Problem solved!
