I want my site to look almost exactly like the demo
Is it possible to use a quick install of joomla and then install the demo installer?
Or do you have to upload and install the demo installer, then the data bases before manually installing joomla?
A little confused. I thought I could do a quick install of joomla and then just upload the template and sample data.
Also, I believe my hosting site no longer uses c panel
need help before I even attempt this
thank you
