1. edmu
  3. Wednesday, 22 January 2025
I have 2 questions regarding Datenschutzerklärung in Footer
- What do I have to do that both rows are in center of the page, where do I have to place a margin-left? (Image 1)
- When I click on the link "Datenschutzerklärung/Impressum" it opens not directly under the Main menu. What do I have to do? (Image 2)
Would you have a URL to an example of this page?
I sent the URL to your E-mail.
.footermenu ul {
padding-inline: 0;
2. Presuming I understand you correctly, try also adding the following to the same Custom CSS field...
.page-header h1 {
width: 100%;
text-align: center;
Thank you for your answer. I tried it but nothing has changed.
I made 2 screenshots:
1. If you click in modul footer1 on DATENSCHUTZ oder IMPRESSUM
2. Everytime the modul top2 and top3 are between the top and the Footer Maincontent. If you click Datenschutz or impressum it should be directly below the header.
... and footermenu and copyright should be horizontal in center. the copyright is a little bit more left. What should I have to do that copyright is in center below Footermenu?
Thank you.
