1. Digijoom
  4. Wednesday, 27 November 2024
I have installed the demo version of Skylar and did not any change. Even not opened the admin-console.
When I'm going tot the example of the news module (under module extensions) the items with the category and date are not like the example on your site.
The date and category in eacht item is shown right from the image.(see the link)
How can I fix this so the date and category is under the title?
Strange is also that in the 'out of the box' demo template the menu 'Features > Module positions' is missing?
The Joomla version from this template is 4.3.4.
Kees
  1. https://digicase.info/skylar/index.php/module-extensions/news-module
Hi Kees
If you install the News module from your download, is the issue resolved?
The 'Module Positions' modules are stored in your trash as they tend to clutter the module manager. They can be restored from thrash if you have a need for them.
You asked me "If you install the News module from your download, is the issue resolved?"
I installed the J51News extension again out of the Skylar-map: Install files. But this didn't help. The issue is still there unfortunately.
I found the module positions menu. Thanks
Kees
Hi Kees
I send you the information to login in my Joomla installation on December 11. Can you please have a look.
Thank you.
Best regards
Kees
Thank you Kees
Thank you very much.
Is it possible to let me know how I can fix this myself? Because I'm busy to make another website with the same problem. Also based on the Skylar template.
Kees
Hi Kees
To resolve remove the override for this module by deleting the folder ../templates/[YourTemplate]/html/mod_j51imagehover.
I think you are mistaken with "mod-J51imagehover", because this is an issue about JNews.
But I deleted the folder 'mod_J51news' and now the layout is correct.
This can be closed.
Best regards
