1. mortk1
  4. Tuesday, 14 July 2020
I installed the Testimonials module on my client's site and we need to make these custom changes:
1) Add a different background color to each testimonial
2) Remove the large gray quote at the top of each testimonial
How can we make these changes?
Mort
Works great...thanks very much!
Mort
1. Sorry to say this option is not available with this module.
2. To amend try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
.j51-testimonials .j51-quote-icon {
display: none;
3. To amend try also adding the following to the Custom CSS field.
.j51-testimonials .item {
padding: 25px;
margin: 20px 0;
background: white;
box-shadow: rgba(0, 0, 0, 0.1) 0px 0px 20px 0px;
border-radius: 4px;
display: flex;
flex-direction: column;
.j51-testimonials .j51-profile {
order: -1;
margin: 0;
.j51-testimonials .j51-text-box {
background: transparent;
box-shadow: none;
Here is the link:
http://webserver17.com/development/susan/index.php/about
The testimonials are at the bottom of the page.
I would need to make these changes:
1) One background color for every 3 testimonials, another background color for the next 3 testimonials
2) The big gray quotes at the top of every block need to be removed
3) Those labels: “Challenge,” “Solution,” “Result” must appear inside the testimonial blocks at the very top of the blocks.
Thanks for your help with this!
Mort
Hi Mort
Would you have a URL to an exampe of your module?
