1. retoo
  4. Thursday, 17 March 2022
I want to delete the lines in the login module / frontend:
- Stay signed in
- Forgot Username?
- Forgot Password?
- Create an account
Reto
Hi Reto
You will find options to disable registration and hide reminder options from your Users -> Manage -> Options panel.
Hello Ciaran
There (User/Manage/Options) you can deactivate the user registration and the sending of the password, but these choices still appear in the login module: I would like to hide these options:
- Remain signed in
- Forgot Username
- Forgot Password
- Create Account
Registered users should only be able to log in and out, without the options forgot user name, etc. Because this choice involves the risk of unauthorized persons registering.
Many thanks
Reto
Hi Reto
You could try hiding these items with some custom CSS. To amend try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
.mod-login__options {
display: none;
Great, that works excellent. I'm happy, thank you!
What confuses me: If I do not enter a password, it shows a new login mask in the frontend, where always "forgot username / password" appears below. What do you advise?
Reto
Hi Reto
Would you have a URL to an example of this element?
Thank you Reto
.com-users-login__options {
display: none;
On a side note I would suggest updating your template to the latest download to ensure you have all the latest fixes (eg. error alerts not displaying when entering incorrect login details).
Excellent! I am happy, thank you.
Reto
I would like to take up this topic again. Despite the suggested CSS codes, there are still pages in the login menu module that allow you to request the forgotten password or user name. How do I make these pages disappear?
Reto
Hi Reto
Hi Reto
display: none;
Thank you, unfortunately this code doesn't change anything, you had already sent it to me before.
If you leave the login fields empty, a new page will appear with the options to click on "Forgot password" and "Forgot username". This means that anyone can request a username and password, which is inappropriate, isn't it?
Reto
Hi Reto
Thank you. The issue appears to be related to Joomla as these options are been displayed regardless of your template (eg. Cassiopeia). The Nina template does not have any user related overrides so should not have any affect here.
okay, good. Thanks for checking.
Reto
