1. webxc-mfx
  3. Thursday, 29 June 2017
Trying to use the Beaumont template custom css field in the "default" style. It doesn't matter what css entry I try, it doesn't have any effect on the site.
The css entries I use in the custom css field for the style that is assigned to the home page works fine.
I have installed the latest Beaumont template.
The attached image show that my custom css field entry for the class "logo" is getting buried in the @media entry.
Any ideas?
Thanks,
Hi Dan
Could you check that you have added the Custom CSS to the correct field. Considering your CSS is been wrapped by a media query would indicate you have added the CSS to the Responsive Options custom CSS options. To avoid the media queries ensure to add the CSS to the field under the Custom CSS tab.
Sorry, I thought I posted my reply last week but it's not here. so...
Yes the entries are in the custom css field. There were entries in the repsonsive fields and I removed them thinking there may have been a problem with them. However it didn't change the problem.
Your Custom CSS appears to be been applied correctly. You can find it in your source on line 266.
Yes, it is working now. Do you know what changed?
Thanks,
Dan
Hi Dan
Nothing was changed by us so you must have fixed this one yourself :)
