  1. ColDee
  4. Tuesday, 13 December 2022
I've updated Hikashop and the product options drop boxes have stretched to 100%
I contacted Hikashop and they sent me the following css, but it hasn't worked:
#hikashop_product_characteristics select{ width: unset !important; }
Could you take a look at the attached screenshot and let me know if I have entered the code in the correct place. Thanks.
Regards,
Colin.
  1. https://bikergearsuperstore.co.uk/helmets/browse-all-helmets/product/hjc-rpha-11-venom-2-red-helmet
I don't want to get involved, but where did you get the path/file in which you pasted the code? Did hika tell you that?
If you want to add something to template51 templates, you can use the area provided for this purpose.
Have you ever tried this way or do you know it:
Joomla Backend in Joomla 4 > "System" -> Template : Site Template Styles -> Your J51_Template Styles -> TAB: CUSTOM CSS
This is where such codes can be inserted. Maybe try it out...
Hi Colin
Checking your site, it appears that your CSS is been loaded and applied?
Sorted. Thanks.
