1. revolion
  4. Friday, 31 August 2018
Hello Joomla51,
I have a custom module which I am using some animation on, but I do not like the stock button that Kaylee comes with so I want to create my own buttons for my modules. I tried following this, Joomla51 Article, but it did not work like I think and it is because I'm not doing the title correctly for the css code. On the site, I want a red button, a white one like in the slider and then a gray one. all buttons the same code just different colors and hover colors. Here is the code for the red one down below. To clarify I want to use the same code for all three buttons because I like the style but I need to have a different color for each button and so the red one I was going to use r2 and white for white and g2 for grey ones.
.btn r2 {
font-size: 38px;
line-height: 1.5;
font-weight: 200;
font-family: ProximaNova, "Helvetica Neue", Helvetica, Arial, sans-serif;
color: #383838;
text-decoration: none;
padding: 5px 35px 5px 35px;
text-shadow: none;
margin: 0px;
letter-spacing: -1.5px;
height: auto;
border-width: 2px;
border-color: #383838;
border-style: solid;
.btn r2:hover {
font-size: 38px;
line-height: 1.5;
font-weight: 200;
color: #cb0602;
text-shadow: none;
margin: 0px;
height: auto;
border-width: 2px;
Once I get this figured on on the title part I can add it to the Module suffix. Am I thinking in the right direction?
Thanks,
JT
Hi JT
Presuming I understand you correctly try using the following selector for your CSS rule..
.r2 .btn
Firstly as you are adding the class (r2) to the containing module class field the class goes before .btn. Note this will give all buttons in the 'r2' module the 'r2' styling.
Secondly, ensure to add a dot before any class name
