1. marcusadamski
  4. Friday, 18 November 2016
I've a quick question on the module widths of Top-1A and Top-1B within the Creative Template. These top two module positions appear to have fixed widths, but looking at the template parameters I cannot see where this is being set?
Can you please confirm, are the module widths hard-coded by the template or configurable somewhere ?
I've attached an image of the "module positions" page, from the Creative Demo to illustrate.
Many thanks
Marc
Glad to hear you found a solution to your issue. Thank you for the update! :)
My apologies - I did look at this this when investigating, but in retrospect, must have looked at the wrong template configuration.
The template I originally looked at had 16.6% widths for all top-1x modules, which confused me - so I thought I was missing something.
However, after rechecking, I see the 60/40% split for the module width within the template configuration. My fault ...
All the best,
Marc
HI Marc
Width options of your modules is available within your template parameters. From your Joomla administration navigate to Extensions -> Templates -> [YourTemplateStyle] -> Module Width.
