Hi there,
I have multiple things related to the Footer menu & copyright area;
1- I have set the base module background opacity to 0.9 where the base modules, the copyright & footer menu area to be transparent but only the base modules appeared transparent but not the rest as shown here;
* this shown on the template I called (J51_Renovate - LGn Home)
The thing is that at the beginning this template reflected transparency on that area but this only happens when I change the module width of base-1 so if I disable the manual widths the area underneath reflects the transparency as shown here;
This is really strange!!! How can I fix that and keep the manual widths enabled?
Here is the URL for your reference http://leangene-jo.com/index.php/lg-home
2- How can I reduce the module hight for the copyright & footer menu area so that it begins from the line as shown here
3- I would like to have the copyright to be on the same line with the footer menu but on the right side, is that possible?
Sorry for the too many questions, but I tried to find an answer within the forum on these issues but couldn't find an answer :S
Thanks,
Mai
