1. Mol4
  4. Thursday, 30 July 2015
I'd like to know how I can put in <?php echo date('y');?> as copyright year so that I don't need to change this manually.
Thanks!
You could try editing your template files directly. In your templates base.php (../templates/j51_habitat/php/layouts/base.php) try replacing the following...
<div id="copyright">
<p><?php echo $this->params->get('copyright'); ?></p>
</div>
With (edit to taste)...
<p><?php echo date('y'); echo $this->params->get('copyright'); ?></p>
</div>
Thanks!
I only had to change the small 'y' into a capital 'Y'.
Greetings,
Ton
If I make the above change in J51_journal/php/layouts/base.php, all that appears in the footer is the current year, nothing else. The information I filled into the “copyright information” section of the style editing window doesn’t show.
Hi E
Thank you Elaine
Both your date and copyright info should be now displaying correctly. A slight change in the PHP was used...
<p><?php echo date('Y');echo $this->params->get('copyright'); ?></p>
</div>
