MENU
  1. albo1
  4. Thursday, 03 August 2017
I would like to remove the copyright in footer without losing the padding.
just to disable it.
how can i do that?
thanks
yes, good solution - thanks Ciarán
Problem solved!
Which template are you working with? Would you have a URL to an example of your copyright?
hello,
its just the regular Enterprise template, which i installed.
thanks
Hi Ciarán,
i solved the Problem so far, im using now an URL (html) instead of the regular copyright info.
But how can i change then the link colour?
#copyright a {
	color: #ffffff;
