I have some thoughts about two module positions in the Emani template.
If I go to the template options > Modules/Component Styling of Emani, I can set base-1 and base-2 background colors.
I also can set footer background color.
The two module positions footer-1 and footer-2 are not available in the template options. I think maybe the idea was to use these two positions like header-1 and header-2, but that should have been implemented in a similar way (that's just my opinion^^).
Why are they no seperate module containers?
I am not able to use them as module positions with a 100% width. If I give them another background color, they are surrounded by the background color of base-2.
I often have to build pages that have several lines of modules, each with different backgrounds, so that at some point you run out of modules containers ^^
On your demo site you do not use the footer modules and I would assume because they are not usable like the other module positions in the other containers. And they are not usable like header-1 and header-2.
Perhaps it would be worth thinking about implementing this differently in the next template?
But maybe its only me with this needs....?
Oli
