Thanks for the nice template.
But there's 1 thing i can't fix.
I have a background image. And with the demo installer the container_bottom_modules is transparent.
But when i install only the template, the container_bottom_modules takes the collor off INLINE, and i will it transparent.
I can't find it. How to fix it?
Joomla 2.5.11
http://praktijk-vitaya.nl/
Regards,
Walko
- walko
- Wednesday, 15 May 2013
Hi Walko
Hi Ciarán,
Now i see that this problem is only on the homepage.
If you go to Contact, the container_bottom_modules is transparent and not black like on the FrontPage. Maybe this will help you.
Regards,
Walko
Regards,
Walko
Thank you Walko
The issue was with the template resulting from an extra closing </div> at the end of the templates main.php (../templates/j51_nocturne/php/layouts/main.php). Removing this </div> amended the issue.
Thanks for solve the problem.
But i think that now there is another problem.
Look at the site on the homepage.
Scroll down, look how it looks now and then go to the second menu-item and go back to the bottom of the site.
Now there is more wrong, i think.
Gr. Walko
Gr. Walko
THis issue is amended by extracting the following in to your templates layouts folder (../templates/j51_yourtemplate/php/layouts) deleting the original main.php
https://dl.dropboxusercontent.com/u/69136519/main.zip
Accepted Answer
Pending Moderation
Does this fix apply to other users who bought Nocturne template, or does it not matter.
Cheers
Paul Edwards
Cheers
Paul Edwards
- # 9
Hi Paul
This should only be a problem when using the contentbottom module positions in which case I would recommend applying the above fix.
- # 10
