1. judolarrance05
  3. Sunday, 05 October 2014
Hi there,
I've just installed mod_j51gridgallery on my site, which seems to of installed fine. I configed it and published it - now when i load the site I'm presented with:
Fatal error: Cannot redeclare hex2RGB() (previously declared in /home/lebidcbp/public_html/templates/j51_classic/php/convert_rgb.php:13) in /home/lebidcbp/public_html/modules/mod_j51hover/php/ConvertRGB.php on line 28
This only happens when the module is published - any ideas?
Thanks in advance
Have you used the GridGallery module that was included with the template?
Yes but I need it to be used for external links - that only links to articles
May I suggest the following post on this subject.. http://www.joomla51.com/forum/8-commercial-templates/4432-renovate-mod-j51gridgallery-link-to-article#7605
If you are using the GridGallery included with your template and continue to get this error message may I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
  3. # 3
Thank you! After a couple of attempts with the code I eventually got it to work - thank you for you help with both issues!
  3. # 4
