I'm not sure if I understand you correctly but have you tried the following:
Main menu entry e.g.: "Obitutuaris" then in the options the tab "Link type" and there the setting: "CSS class for link" -> "columns-3" and then save
(but I don't know your template, that's how it works with the J51 payment templates)
Yes that is exactly what I have tried but its still one column. I believe his is an older J51 Classic Free template. I know that columns are possible with this template but the format to create them is not working.
