1. ziggy
  4. Saturday, 15 June 2013
I'm using the template "bordeaux" and I created a module in "hornav" according to the explanations that we gave to another user. http://www.joomla51.com/forum/support/commercial-templates/hornav-module-not-visible-in-avenue#627
The problem is that now I drop down menu appears with the colors indicated in Setup of the template itself. What is happening?
Attached photos.
Also I would be interested to know how I can put the language selection flags beside the menus instead of leaving just below.
Thanks and regards.
http://img29.imageshack.us/img29/4422/5hk.png
http://img515.imageshack.us/img515/1958/e4m.png
Hi Victor
The parameters of the template will continue to style sub items to your menu even if you have converted to a module position. Is there an alternative way in which you would like to style your menu sub items?
Would you have a URL to an example of your language flags and we will put together for you the needed CSS to amend their position.
Thanks Ciarán.
Before the establishment of the module "hornav", submenus appear in the same style hornav menu. That is, dark background and brown lettering. But now I see, as you can see in the previous post image, the light background. The problem is that in the last submenu no longer appreciate good lyrics.
I would like to go back to being as before. Is there any way?
Yes I am interested in the link to an example of the flags to change the position.
Would you have a URL to an example of your dropdown menu and your language flags?
Yes please.
Thanks Ciaran, I've managed to fix it and leave the selection of languages ​​as wanted
