1. pablo
  3. Tuesday, 17 May 2016
Sorry,
can not find were to change color of buttons in navslidshow, displayed on my new homepage: http://www.bloderpelze.at
:dry:
Hi Pablo
Try adding the following to the Custom CSS field of your templates parameters (edit to taste)..
.navslideshow-nav ul li a, .navslideshow-nav ul li a:focus {
background-color: #842555;
works fine, thx :laugh:
to make it perfect, is there also a solution for the mouse over color? Should be the same but slightly darker?
thx again best regards
Hi Pablo
To set a hover color try the following (edit to taste)....
background-color: #611b3f;
This time no effect! Buttons colored like before and hover color still blue. thx for helping. :dry:
My apologies
The following should do it...
.navslideshow-nav ul li:hover a {
love you! .. works..
:laugh:
