Message
OSM_INVALID_SUBSCRIPTION_PLAN
  1. lutherbli
  3. Wednesday, 07 March 2012
Hello, I wanted to know if it is possible to collapse the right column (sidecolumn) of the template when there are no active modules.
you have the code to be integrated into index.php?
Many thanks for your answer and congratulations for the template
Your sidecolumn module position should collapse by default if no module is enabled (http://demo.joomla51.com/0072/index.php/template-layout/single-column-layout)
Solved. many thanks. There was a module that I had not seen.
