1. fg74
  3. Tuesday, 25 July 2023
I'm using Colette template, latest, and I'm facing an issue with the splitted main menu.
When I publish a download extension module, the menu is not splitted anymore, displayed on the right of the screen and overlapping the logo.
Perhaps that could happen with other extensions, but for now I got this isssue only with downloads extensions (tried Phocadownload, dropfiles, jdownloads and Edocman (with this last, the problem happens also with the plugin in content).
Any idea ? Thanks for your support
Joomla 4.3.3
PHP 8.1 (same with 8.0)
  1. http://nordique-vallee-chamonix.org/
Done !!
This issue should be now resolved. By default the template uses jQuery to split the menu items however some modules are loading an older version of jQuery that is not compatible with the template.
For a solution, I have added the following to the Head Custom Code field of your templates parameters (Extensions -> Template Manager -> YourTemplate -> Custom Code -> Head Custom Code)...
<script>
document.addEventListener("DOMContentLoaded", function() {
var $lis = document.querySelectorAll(".hornav li");
var $lisLength = $lis.length;
var $lisHalf = Math.floor($lisLength/2);
for (var i = 0; i < $lisHalf; i++) {
$lis[i].classList.add("menu-split");
</script>
This splits the menu using vanilla JS instead.
Thank you for your support !
This might have been a solution but while you solved this problem I identified the module which is responsible and contacted its support : I think they will have to update the jquery loaded in their module and if not I'll resign myself to install another one that offers the same service.
Your template works fine and the issue wasn't part of it !! thank you for your help .
I'll let you know if necessary
And...
While waiting for the component to be updated, the problem has been solved by installing JQuery Easy !!
Thanx again and regards
