1. bcrawley
  3. Saturday, 10 December 2016
On the layered slideshow you can make the text box clickable. Is there a slide show module that the entire graphic is clickable to take you to another page in the site? I've been going through the various templates and extensions and am not seeing that as an option through Joomla 51. I wanted to inquire before looking at other slide show extensions. Your templates and extensions are great and I appreciate them and all you do!
Sorry to say our default Slideshow module does not allow the option to add a link to images. We have however just updated the LayerSlideshow module to our Valencia template so the entire image is now linked which may offer you a suitable solution. To obtain simply re download our Valencia template and it's modules.
Hey Ciarán,
I changed out the slide show module and it does what I want but I can't get the images to size correctly. I'd like for the layerslideshow to only be the width of the template (1140) and I would like for the module NOT to blow up the images. I've got the module set to be the height of the image but it's blowing up the image and cutting content off. Can you assist with this? I sent you an email with login information.
http://www.reachtherest.org. I also sent you an email to [email protected].
max-width: 1140px;
This worked perfectly! Thank you so much!
Excellent.. thank you for the update! :)
