1. lidacha
  3. Monday, 03 June 2013
[color=#000088]Clarity, Joomla 3.0, Safari, http://www.paulakool.com/lc3[/color]
I wanted to get rid of the dark top bar and removed it. So far so good. But the shadowing did not match the photos I had adjusted for the slideshow as the header moved up.
So I changed the background of the dark top bar to none (all with help from earlier forum posts) and removed the search box and the social icons.
You can see that in the first image (menu-now.jpg) I attached.
What I would like is to stretch the header upwards to the top and move the logo a little up as well.
If possible I would like to place social icons in the top corner. (see the other attachment, menu-what I want.jpg)
I have searched the css files, tried to change things here and there, but with my very limited knowledge I cannot get it to work.
I hope I was able to explain well enough and I hope you can help!
Thank you very much in advance.
Lida
Update…
After a lot of trial and error I managed to adjust almost all I think. Now I only need to try to get the social icons back on top.
Have a look at http://www.paulakool.com/lc3.
I changed the following in nexus.css:
[color=#0000ff]r.43 In Photoshop adjust height of templates/j51_clarity/images/bg_bar.png to 145px instead of 105px (40px on top, stretch white to the top).
r.44 height:145px; instead of 105px
r.81 height:130px; instead of 90px (#container_spacer1)
r.88 height:0px; instead of 40px (#container_spacer3) to remove the dark top bar.
r.312 #subMenusContainer {top:-50px;} (was {top:0px;} )[/color]
I hope my changes do not effect any other things in the template or do not cause any errors at some point.
I hope someone can confirm this.
Now I need to try the social icons back up.
Thanks for looking.
Lida
Hi Lida
Your adjustment appear perfect and should not effect other element of your template.
Your social icons do however appear to be placed behind your menu background which you have extended. To amend this try adding the following to the Custom CSS field of your templates parameters...
[code type=css]ul#navigation li a {
position: relative;
z-index: 99;
}[/code]
Note because the social icons image sprite is white you may have to adjust the sprite to a darker color so the icons contrast with your menu background (http://www.paulakool.com/lc3/templates/j51_clarity/images/sm_icons.png).
Thank you so much! It works… I only have to darken the icons now.
And thanks for the great support!
Lida
