1. Katmandhu
  3. Thursday, 14 March 2013
I am having a problem with the side columns showing up on mobile devices & the Austin Slider shows a picture that isn't included. http://bargoddess.com/SCCC/ I am pretty sure the menu doesn't show, because I had to use a 3rd party extension to get it where the client wanted it. There is no navigation at all. I have no problem with http://bargoddess.com, which uses Bordeaux. I added a footer menu, but don't like the way it looks.
Any ideas?
Thanks,
~Kat
Exactly the problem! Thanks!!!
Hi Kat
Have you enabled the 'sidecol' module position with in your templates 'Responsive Options' (Extensions -> Template Manager -> J51_Clarity -> Responsive Options)?
Worked for the menu, but side columns do not show in mobile devices. Is there a way to make the width flexible for the smaller browsers or viewers?
Hi Kat
To remove the background to the footer area of yoru template try adding the following to the CustomCSS field of your templates parameters..
[code type=css]#container_base, #container_copyright {background: none;}[/code]
You will find that this will make the footer content hard to read due to lack of contrast to your background. A solution to this would be to add a shading to the footer it making semi-transparent with something like...
[code type=css]#container_base, #container_copyright {background: rgba(0, 0, 0, 0.6);}[/code]
Okay, the footer menu shows up, but I'd like to modify that to transparent, but don't know the container # and not sure how it will look. I'm going to play with changing it to a module position & pray it still shows up.
My nephew (the one that gave me this job for his client) says that I need to somehow add "flexible width" to the template settings. All I can find is a pixel setting.
Just playing & praying here...
:evil:
kat
