1. Wayne Webb
  3. Monday, 21 July 2014
[color=#bb0000]Here is my site[/color]. How do I make the horizontal navigation module position responsive? In the back end I have all the Responsive Options set to On.
The hornav_module class takes over at a certain point, anything roughly below 750 pixels. However, between 750 and 944 pixels wide my horizontal menu gets put behind the site logo. The menu would likely work fine if aligned to the right with the overflowed menu items wrapping to a second line.
A similar thing is happening to my Login Form to the right though the pixel width values are slightly different with the problem being between 944 pixels to 1200 pixels.
Cordially,
A. Wayne Webb
Hi Wayne
To amend these issue could you try adding the following to the Custom CSS field of your templates parameters...
/* Hide default hornav menu */
#hornav{display:none !important;}
/* Show mobile hornav menu */
#container_hornav_mobile{display:inline; z-index: 99; margin-top:13px;}
.js #mobile { display: none; }
#hornav_mobile {margin-top:0px;}
.wrapper960, #header_items, #header {width:960px;}
Thank you Ciarán,
Between 944 and 1023 pixels the drop down menu selector scrolls off the page to the right. Additionally those items in sidecol-a are off to the right just off screen.
As for the RokAjaxSearch results pop-up hiding behind items, I'm working on it.
Thank you for all your help.
Hi Wayne
Thank you Wayne
I have made some changes to your responsive.css which will hopefully sort out the issues you are having.
Thank you Sir.
