1. eternitygraphics
  3. Friday, 11 October 2013
I have a strange issue happening. Theme fonts are displaying perfectly for the public user, but once someone logs in, the fonts change to Times Roman (which messes up my layout).
Any ideas why this might be happening?
http://rabbihayley.com/
Thanks!
Clara
May I suggest sending temporary access to your site to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
Thank you Clara
body {
font-family: 'Comfortaa',cursive !important;
That just makes the body font cursive. If you notice my headings and menu fonts are changing as well. I did put in the font I want into the css as well.
Hi Clara
Google fonts appear to have an issue when going from HTTP to HTTPS within the same site. I have added the following to your Head Custom Code field of your templates parameters removing the HTTP when loading the Google font which appears to have resolved the issue...
<link href='//http://fonts.googleapis.com/css?family=Comfortaa' rel='stylesheet' type='text/css'>
<link href='//http://fonts.googleapis.com/css?family=Dancing+Script' rel='stylesheet' type='text/css'>
May I suggest the following post which should resolve your error issue.. http://www.joomla51.com/forum/support/commercial-templates/arkadia-google-fonts-not-displaying-properly
Once done you can remove the above code from your Custom Code field.
