1. Tompakidf2
  3. Thursday, 05 December 2019
I am using J51 Central. Website is https://www.weathercyprus.com/
When I inspect the website code using chromes Inspect Code, I get more than 40 warning all having the same description as below:
A cookie associated with a cross-site resource at http://google.com.cy/ was set without the `SameSite` attribute. A future release of Chrome will only deliver cookies with cross-site requests if they are set with `SameSite=None` and `Secure`. You can review cookies in developer tools under Application>Storage>Cookies and see more details at https://www.chromestatus.com/feature/5088147346030592 and https://www.chromestatus.com/feature/5633521622188032.
I believe is caused by the template. Does anyone have a suggestion on how to fix that? I help is highly appreciated.
Best Regards
Sorry to say this should not be a template related issue as the template itself is unable to set any cookies. If you enable the Protostar template and find that the issue is no longer present, try disabling all modules with your J51 template. If the issue stops, enable each module until the issue arises to find the culprit.
