1. bibbp
  4. Monday, 19 June 2023
Ciaran,
I'm getting this error repeatedly having installed Chloe J4:
500
BEHAVIOR::CAPTION NOT FOUND.
An error has occurred while processing your request.
You may not be able to visit this page because of:
an out-of-date bookmark/favourite
a mistyped address
a search engine that has an out-of-date listing for this site
you have no access to this page
500 behavior::caption not found.
  1. https://www.oasttheatre.com/
Two things come to mind.
Make sure you uploaded the correct file. You need to unzip the template download file and use the template file inside "Joomla! 4.x Install Files"
Check you settings. You might need to increase the value of PHP variable: upload_max_filesize for your site/server.
error seem to be here: JROOT/templates/j51_chloe/html/com_content/article/default.php:24
...and the use of JHtml::_('behavior.caption');
I have commented out this line in article/default.php:24
and in featured/default.php:14
This is in an unstable situation, I suspect some classes are not working, eg "button".
Undo this: I have commented out this line in article/default.php:24
Try deleting the templates html folder (../templates/j51_chole/html) and re-installing your template
Wonderful... that seems to have worked!!! Thank you
Should I take the same approach for the Boutique issue?
Kind regards
Peter
I am installing Chloe on another site, and get the following error:
There was an error uploading this file to the server.
Unable to find install package.
I tried deleting the html folder (as above) but no success. I am using MigrateMe4, might this have an impact?
Peter
