I have to use carousel module and I need to rebuild the carousel module to display more than 14 columns.
Can you tell me something helpful about the carousel module?
I would also suggest changing the following in your modules default.php to match the number of fields in your XML (../modules/mod_j51carousel/tmpl/default.php - LINE48)...
