1. Kyna
  3. Saturday, 28 July 2012
I am running Chimera with a 2.5.6 Joomla and I am trying to show an external stud dog's pedigree in a wrapper. It should look like that.
To show it as a single Colum layout I did as proposed by you:
For a single column layout simply disable all modules in the SideColumn module position.
Unfortunately the i-frame now is displayed a lot smaller like this
BTW The wrapper works well with a two colum layout; but for these pedigrees I need the whole width.
Any ideas, how I could solve this problem?
Best regards, Kyna
Hi Kyna
May I suggest adding the following to the Custom CSS field within your templates parameters..
[code type=css]#content_full {width: 100%;}[/code]
You may... as it works perfectly.
Thanks a lot from, Kyna
