Try adding the following to your templates header.php (../templates/j51_chimera/php/layouts/header.php) just after
<div id ="header" class="block_holder"> (line1)..
<div id="newmodule">
<jdoc:include type="modules" name="newmodule" />
</div>
You must then style it with the following which you can add to the end of your templates template.css (../templates/j51_executive/css/template.css)
[code type=css]#header {position: relative;}
#newmodule {
position: absolute;
height:50px;
width:200px;
top:10px;
right:20px;
margin:0;
padding:0;
z-index:99;
[/code]
Edit the above to your own taste in particular top, left. height & width under #newmodule.
And that should be it. You'll find the position won't be listed in the positions dropdown so simply type it in to create (
newmodule).
