1. MikePritchard
  4. Wednesday, 24 June 2020
Just installed, most recent everything: J version, php, no extensions added except Akeeba.
https://calvarychapelreno.org/new/
I went to J51_Chelsea - Default template and change the info in the copyright section. Saved cleared cache. Cleared it out completely, saved, cleared cache.
But it won't change.
Can you help?
Thanks much.
  1. https://calvarychapelreno.org/new/
One possible cause is described.. https://www.joomla51.com/tutorials/troubleshooting/template-options-not-effecting-frontend in the following article
If that article is not relevant, may I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our reference please paste a link to this post in your email.
