1. ticmic
  4. Wednesday, 14 September 2016
Hi since I have installed the Chelsea Template my EasyBlog component will not let me login from the front end:
The login is the padlock icon on the far right
http://hungaryheartsdogrescue.com/index.php/news2
When I revert the template back to a Joomla template it works fine, any ideas please
I have loaded JQuery and set it up as you have instructed in your tutorial but still it does not resolve the problem
thanks
To amend we have added the following to the Custom CSS field of your templates parameters...
#container_main .wrapper960 .collapse {
overflow: visible !important;
Thanks so much, this is also needed with the Beaumont template
Hi again,
I have just noticed that although the login now works when I go to publish the blog the publish button at the bottom of the page does not function, is this a template issue?
thanks
Nigel
Login details are the same as before
HI Nigel
Are you having the same issue if you enable one of the default Joomla templates (Protostar)?
