1. SvenGuns
  3. Wednesday, 17 July 2013
How can I change the color of menu placed in the sidecol-a module position of the J51 Impulse template
To change the colour of the background of your sidecol modules try adding the following to the Custom CSS field of your templates parameters where #DDDDDD is the new background colour...
.sidecol_block .module {background: #DDDDDD;}
No result with this. There is nothing in customCSS field for the moment, do I have to add extra instructions?
Forgot to click on save! It works THX
I want to chage de color of the tekst and titles in the sidecol-a module position as well. How can I do this (Don't have enough CSS expierience (sorry))
To change the colour of the titles of just the sidecol-a module position try adding the following to the Custom CSS field...
#sidecol_a .module_header h3 {color: #000000;}
Where #000000 is your new module title colour.
For the sidecol-a text also adding the follow...
#sidecol_a .module_content {color: #000000;}
Is it also posible to change the background colour of the content-bottom module?
Try adding the following to the Custom CSS field of your templates parameters...
.contentbottom .module {background: #EEEEEE;}
Where #EEEEEE is your new module background colour.
Is there a list of CSS codes which can be used with the J51 templates? If I have the codes I don't have to ask for it each time I want to change something. It sees thah the codes have a system, I only need the beginnen of the codes (the prefixes (coulor etc.) can I find out by my self
Sorry to say at present we do not have a list of CSS selectors available for our templates however these can be easily found by using the inspect element function in tools similar to Firebug (https://getfirebug.com/). Pressing F12 in most browsers will give you similar functionality.
